Fascia not matching up on elevation
The height of the fascia is not matching up in the side elevation. However,
the front elevation shows them to be at the same height. I checked the roof and all the slope segments are set at 5/12 and the overhang is set at 2' for all segments.
Below is a screenshot of the side elevation and the front elevation.
Mirko.Jurcevic
it looks to me that your elevation symbol actually cuts the roof (elevation is actually a special kind of section).
Try to move elevation symbol and it's cutting line away from the roof (away from the building) and check elevation again.
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
PijPiwo
Your elevation view cut line is closer to the building than your roof overhang. Move it further away from the building.
I moved the crop region line but that didn't have any effect. You may be talking about something else. I tried to get to the cut plane in the floor plan but don't know where it is.
I am relatively new to revit, I have heard about adjusting the view in elevations but don't know how or where to start.
Mirko.Jurcevic
Please spend 8 minutes of your life by watching this video to see how it's done.
I am pretty sure the problem you have is in those "blue lines" guy's mentioning in the first two minutes of the video.
Position of the "blue line" should be away from the building in your case.
https://www.youtube.com/watch?v=gFU7IUti-Zw
Mirko Jurcevic
That fixed it!
The video was an inspirational 8 minutes
