Family types with different models
tmccar
Advisor Advisor
Message 1 of 16
tmccar
Is it possible to have a family where its various types are different models (so for instance a chair family would have different seat and back colours), or are you confined to working with one model and  its properties?
    I'm asking because I have a 3D chair which was modelled in Autocad and I can change the colour of the seat and back because they are seperate 3d solids, but in Revit it comes in as one model.
Replies (15)
Message 2 of 16
Edwin.Rense
You might if both seat an back are different subcategories, than you can use filters in the view.
If the colors have to differ in one view i would use nested families for the seat and back with shared parameters for the color so you can change them from the model per instance.
Maybe if you upload the chair family someone can take a look at it.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
Message 3 of 16
tmccar
Thanks, I have uploaded the file now.
Message 4 of 16
mhiserZFHXS
You can either use visibility settings or use <family type> parameters to do this.
And don't use CAD files to make families. Invest the time, do it right, and make it Revit.
Message 6 of 16
Edwin.Rense
Like @mhiserZFHXS stated, do not use DWG as 'Imported Categories' it makes things more complex.
Create a furniture family with a 'frame' a 'seat' and a 'back'.
Optional: Create subcategories for all 3.
Create the desired number of types (combinations of color. If you use two colors for back and seat there are 4 types.)
Example: Frame is always black:
Type 1: Back+Seat are RED
Type 2: Back and Seat are BLUE
Type 3: Back is RED and Seat is BLUE
Type 4: Back is BLUE and seat is RED.
Use existing or create the new materials.
Create (type) parameters (seat_color and back_color) to control the material.
Kind regards,
Edwin Rense
Cadac Group AEC BV
Cadac Group .
Message 7 of 16
What about View Specific Graphic Overrides?
Message 8 of 16
tmccar
Yes but the seat and back are fairly comnplex - difficult to  model in Revit. And also the frame.
Message 9 of 16
Message 10 of 16
Here's my quickie solution. See attached.
NOTE: Frame is Shared and Nested into Seat and Back Family. Family 1=Seat/Back w/ Nested Frame. Family 2=Frame.
Message 11 of 16
mhiserZFHXS
Are these being rendered, or is this for documentation only?
Message 12 of 16
tmccar
Not for rendering - more for mockups I believe.
Message 13 of 16
tmccar
Thanks for that
Did you set colours in Autocad?
Message 14 of 16
Thanks for that
No. I changed the colors via Override Graphics in View By Element.  I showed a screenshot above.  You could also change colors via Filters.
Message 15 of 16
mhiserZFHXS
Then don't worry about all of the complex geometry. Model it in Revit and get it close.
Message 16 of 16
Have you tried BIMObject.com? I found over a dozen (maybe more) Revit Families there for chairs that are very similar looking to yours.
