Family Creation rotation problem
6 REPLIES 6
emodderman
960 Views, 6 Replies
OK, I've got a question about the difference between 2 families being nested into the same top family.
Both of the families are being placed on the plane of a ref line, then locked into plate to another ref like at 90deg from the first - as per another post on here - and this works for one and not for the other. one family is literally a save as of the other and then the geometry changed.
BUT if i put in the WORKING one first, lock it into place, where it rotates just fine, and then i use the type selector to replace it with the NOT WORKING one, the second will rotate perfectly. but if i place the NOT WORKING one first, it refuses to rotate when locked.
AND if i get the NOT WORKING one working based on the previous method, when i reload it with any changes - not just geometry changes, just parameter value changes, or no changes whatsoever just a reload - the NOT WORKING one will break it's constraints when rotated.
This one is driving me nuts. There is clearly something wrong with the NOT WORKING family, but i don't understand what it could be.
Labels (3)
6 REPLIES 6
emodderman
in reply to: emodderman
file
Are you talking about the Z Rotation? Isn't the Z Rotation Axis Parameter of the Nested Family supposed to be associated to the Z Rotation Parameter in the Host?
...this is what I'm referring to:
emodderman
 no! actually, that part works just fine when connected. i'm talking about the XY plane.
Okay. Still trying to understand the issue.  BTW: Uncheck "Always Vertical" in the Nested Work Plane-Based Families.
emodderman
OMG it was that **** checkbox. it was unchecked in WORKING and checked in NOT WORKING. i KNOW that rule too. i completed missed it. i tried so hard to not post this cause i was sure there was a stupidly easy answer. *sigh*
HA!  **** happens. TGIF.
Cheers!
Forma Design Contest
Technology Administrators
