Failed Upgrading 2019 to 2020: Corrupt Model Error
bstockton_sapp
Message 1 of 10
bstockton_sapp
Was attempting to upgrade a series of R19 models to R21 and I keep on the error that the files is corrupt and needs to be repaired manually. I believe several models were created off the a model in the group so the same issue has most likely translated to others.
I have tried detaching, purging, deleting cache files, renaming files, the whole shebang. I have tried looking at the journal but I haven't been able to decipher the issue and find the error.
If anybody is looking for a challenge could you please take a look or offer and suggestions.
Replies (9)
Message 2 of 10
martijn_pater
Did you audit the model while updating? (Check audit when opening from dialog)
Message 3 of 10
Does your R19 and R20 have the same add-ins?
Message 4 of 10
bstockton_sapp
audit while opening the bim360 model. Saved-as to local. Audit opening model while local. Saved. Open model in R21 with audit and get corrupt model, restore manually.
Message 5 of 10
bstockton_sapp
Same addins. I have even deleted the addin folder in the directory for both R19 and R21 while trying to upgrade.
Message 6 of 10
Yien_Chao
@bstockton_sapp ,
i can take a look i you dont mind to send link.
Message 7 of 10
syman2000
Do your model have Revit links or CAD links? Perhaps unload them first in 2019 and try upgrade it. Sometimes links can cause the upgrade to failed.
Message 8 of 10
RobDraw
Since you have ruled out/tried the obvious problems/solutions, it might be time to start digging into the families. I saw a AKN page last week describing how to analyze the families. Unfortunately, it's a one by one process.
Rob
Message 9 of 10
bstockton_sapp
I have exported all families from the project. The only family errors during that process were regarding objects that needed to have their constrains removed.
Earlier in troubleshooting I didnt find some families that would not export or open to edit, reloading them seemed to correct that issue.
Message 10 of 10
bstockton_sapp
Thought of this as well. Tested a model that was in an early phase that didn't include any links (dwg or revit) and the file got the same error while upgrading.
