Segmented + inclined longitudinal section, possible?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
mariomelendez
1100 Aufrufe, 2 Antworten
Let's say I have a building which is L shaped at an angle, and I want a longitudinal section spanning the entire length. Something like this:
I could do 2 sections, one for the inclined part and one for the horizontal part. But I was wondering if it's possible to do it in a single section.
I know sections can be segmented and you can move the section plane perpendicular to the original. But is it possible to rotate a section segment like shown above?
Tags (1)
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
martijn_pater
als Antwort auf: mariomelendez
No, use two sections placed next to each other on sheet.  You could draw them on top of refplanes though ie.
Nachricht 3 von 3
mauricio_mssf
You'll have to create two sections and stitch them together on sheet.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
