Is there a potential fix for Revit 2018 failing to print as a PDF with Adobe. I was forced to upgrade to Revit 2018 and so far it has been less functional than its older counter part. I have downloaded a secondary pdf program, but it isn't as functional as Adobe was.
Did you use Bullzip pdf printer? it suppose to work smoothly n revit 2018
Hi @debner
Please see PDF solutions available to use for exporting and printing from Autodesk Revit
I would need to see your journals and Revit file to reproduce this issue.
A few questions:
Looking forward to your reply.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi @debner
A few questions:
Viveka CD
I'm not sure if there is a conflict with a certain font, I consistantly use the same font types.
Acrobat and Adobe Reader are not open.
No external links to other files.
Windows 7
Not on a Mac
I am using two mointors with Evga nvidia 1050Ti.
I have attached the journa.txt that was created at about the same time I attempted to print. Thanks in advance for your help. Let me know if it is the wrong thing, there were a couple of them.
Windows 7
Not on a Mac
Hi @debner
Thanks for sharing your journal. I will require your Revit model to reproduce the error and investigate further.
I can share a private folder if you'd like. Let me know.
Viveka CD
Hi @debner
Viveka CD
