Failed to print PDF Revit 2018
debner
debner
Is there a potential fix for Revit 2018 failing to print as a PDF with Adobe. I was forced to upgrade to Revit 2018 and so far it has been less functional than its older counter part. I have downloaded a secondary pdf program, but it isn't as functional as Adobe was.
deliverator
Did you use Bullzip pdf printer? it suppose to work smoothly n revit 2018
Viveka_CD
Hi @debner
Please see PDF solutions available to use for exporting and printing from Autodesk Revit
I would need to see your journals and Revit file to reproduce this issue.
A few questions:
  • Does this happen with a specific font?
  • Is Acrobat or pdf reader open when printing?
  • Are there always linked Revit files? Does problem stop if there is no Link?
  • Which windows version are you using?
  • Are you in Bootcamp/ Mac environment?
  • Are you using multiple monitors?
Looking forward to your reply.
debner
I'm not sure if there is a conflict with a certain font, I consistantly use the same font types.
Acrobat and Adobe Reader are not open.
No external links to other files.
Windows 7
Not on a Mac
I am using two mointors with Evga nvidia 1050Ti.
I have attached the journa.txt that was created at about the same time I attempted to print. Thanks in advance for your help. Let me know if it is the wrong thing, there were a couple of them.
Viveka_CD
Hi @debner
Thanks for sharing your journal. I will require your Revit model to reproduce the error and investigate further.
I can share a private folder if you'd like. Let me know.
