I was wondering if anyone had any experience managing projects in a single facility and how they format the project(s) with Revit. The following is a basic look at my questions. I have a client who owns a very large facility and within this facility many projects are taking place. I have a master Revit file that consists of all the existing components, but we also need to create New Construction and Demolition. Sometimes a project may not come to fruition, while others do and then become existing components after construction. Is there a project management process with Revit that will allow you to remove projects that are not accepted without redoing demolished and new work? I was think that Phasing may provide the answer by creating a phase with the name of the project e.g. phase name = Project 01 and Project 02, etc.., but as far as I can tell, I can't view Project 02 without seeing Project 01. The other method I thought would work is Design Option. Design options seems to be the way to go, but can an entire design option set be moved to existing, or deleted? And can you show demolished items in a design option and still maintain the existing phase? Any ideas on this subject would be appreciated.
Hmmmm... I didn't think of that. You're right.
So then my suggestion goes back to my first one, wherein you just keep adding new phases for each new project as is appropriate. Still, occasionally do a Save-As with a unique name in order to capture a frozen "current" snapshot after each completed project, and try to keep the master cleaned up every so often by taking the projects/phases created the year before and consolidating them into the Existing phase, getting rid of their project-specific views/sheets, etc. Maybe this can keep the master from becoming too unmanageable over time.
The master file needs to exist for maintenance, not just new projects.
For AutoCAD or Revit, the projects should exist separately, and only the bare bones items be imported into the master model(s).
I don't just work under the assumption that the model needs to be clean enough for a lesser skilled person to find what they need, but also that the model will be linked and published into an IWMS/CAFM system, and it needs to be as lean and mean as possible, so that the web interface is as simple and easy to navigate as possible for even LESS skilled users.
... don't get me wrong, this is an excellent thread and I'll be re-reading it a few times to see if I can make my life easier with the utilization of phasing and any other suggestions. One thing about us facilities folks, we're cheap and slow, but, our main concern is what gets the job done at the end of the day.
I am glad to see all the activity on this thread. It has been a huge issue with me and some of my clients, but for the last few months I have come up with a more refined management process that has been working very well. I have some video clips that step through this project management process that I will try and upload to youtube. I will reply to this thread when it's available.
Revit Facility File Management (Customer specific, but basically universal)
Uploaded video link below to youtube. Please let me know if this is helpful and or if you have any comments and ideas to improve.
Thanks.
Melanie,
I hear what you are saying all the time from my customers, so you 100% right on with your comment. Please review my short video presentation that I uploaded and linked in a previous thread. I would like your feedback. Thanks.
Really appreciate you sharing so much on the topic. I'll take a look at what you've posted and let you know what I think. 🙂 Thanks.
