Hi
When I create elements in Revit like a simple wall through Dynamo there are two problems.
Sometimes the elements are created and sometimes not. There is only a line in Revit but not the wall. Also when I close a Revit project and save the Dynamo scrips and open the dynamo script again, the elements disappear.
Is there a simple way to be able to open a Dynamo script that has all the elements for a totally new Revit project and all the elements that were created in Dynamo comes back to the new Revit project?
Thanks for replies in advance
Gelöst! Gehe zur Lösung
Gelöst von shefypattambi. Gehe zur Lösung
Hi @Anonymous
Hi your revit element is missing when you run the graph again on another curve ?
You can post this issue on dynamo forum.
Hi
Yes, the script that I used, created the wall but when I close down the Revit project and create a new Revit project but using the same Dynamo script, the wall disappears.
Thank you, I will look for that code. I dont know why but it worked when I opened a revit project in architecture project instead of structural. But I will look at the python code and get back if there is a problem. Thank you.
