Facade with metalic profiles and panels
9 REPLIES 9
Message 1 of 10
freeriderfx
671 Views, 9 Replies
Hello everyone i was wonderig wich method will you use to do a facade with metalic panels ans profiles like in the photo._L7C5300.jpg
I´m not sure if I´ts plain or it has some setoff
Thanks in advance
9 REPLIES 9
Message 2 of 10
in reply to: freeriderfx
Mass and Wall by [Mass] Face.
Message 3 of 10
freeriderfx
in reply to: barthbradley
But how to set the profile and the panel?
Message 4 of 10
The ridges and valleys of the surface are the mass form. The panels lie flat on the surfaces of the mass.
Message 5 of 10
bin
Mass, and create those triangular faces separately.
Message 6 of 10
you can do it by using:
  • Mass Family to create the basic form - as shown in my screencast . Use Add Profile and Add Edges tools and then move vertex to obtain the desired form.
  • then once loaded into Project , use wall by face - the wall material will be metal with cutouts. The final result will be something like this:
https://knowledge.autodesk.com/community/screencast/69591a78-1ae2-4ffa-a2c0-7d301b8273d0
Constantin Stroescu
Message 7 of 10
Thanks so much, that was what I was looking for!!!!
Message 8 of 10
IS THE A WAY TO MAKE A CONNECTION LIKE THIS???IS THE A WAY TO MAKE A CONNECTION LIKE THIS???
HOW TO MAKE A STRUCTURAL CONNECTION LIKE THE ONE OF THE PICTURE????
Message 9 of 10
bin
Maybe you can get some ideas here:
Message 10 of 10
freeriderfx
in reply to: bin
Thanks, I like your approach, actually !!!!
I´m going to try it
