Hello all,
I'm linking this file to a 3D model - how do I remove the very bright colours as they are carried across when I export for the forge.
I just wish to remove the bright colours permanently but I'm not sure where they are located.
On realistic setting it results in the colours acting as a stroke if that sheds any light on what kind of material/filter they are.
Looks like it's coming from the Duct System Type Properties in the Project Browser.
From my blog post on the subject
"If you don't want to see those colors you CAN override them with Filters. I've opened Visibility/Graphics and then created a Filter. In the Filters dialog, if you select only the Duct categories, Flex Ducts, Flex Pipes, Mechanical Equipment and all the Pipe categories, then the "Filter by:" will allow you to choose "System Classification", set it to "is greater than" and "" (empty field)."
Steve Stafford
To remove this color you can do it by non check on duct color fill in visibility of linked HVAC file .
