Revision Clouds in Schedule Views
jmartucci2
jmartucci2
If you cloud something in a schedule on a sheet but then you need to either remove or add a row you have to go back and move all your clouds back to the cells they were originally clouding. We should be able to have the revision clouds move with the cells as rows are added/removed.
If you cloud something else, says a door, don't you need to move the revision cloud when the door moved as well?
jmartucci2
Yes but when you remove or add a door that doesn't impact the door in your schedule that has been clouded, you still need to go to your sheet and update the cloud on the schedule. If you have 80 doors in your schedule and one of the rows at the beginning of the schedule gets deleted, any revision clouds below that row need to be moved. Which means you need to unissue the revision, then reference the PDF you printed when you posted that revision to find what should be clouded, etc... It just makes unnecessary work and errors if not thoroughly checked.
