Extrustion bend parametric
Message 1 of 12
I am trying to create a family where in an extrusion there is a bend, that is depended on several parameters. The bend needs to move when I change the parameters A, AA, B, BB and R. If I understand correctly I first need the calculated the center point for the bend. So that is why I made X en Y parameters. But I don't know how to calculated X and Y, can someone help me with this or offer me a different solution?
Replies (11)
Message 2 of 12
Revit_Whisperer
If you draw the extrusion with all of the lines intersection at the reference plane intersections, it will automatically adjust.  I did a quick video on what I mean.
http://screencast.com/t/NWMKRzLB
Message 3 of 12
@Revit_Whisperer  I think he needs R to be an input parameter as well.
Message 4 of 12
@Anonymous  I use Generic model adaptive.  It is Revit 2017 format.
EDIT: regular generic model works too.
Message 5 of 12
constantin.stroescu
I saw there are many answers...Anyway as long as I did a try I put it here...in Revit 2016
Constantin Stroescu
Message 6 of 12
Thx for the families and video's. But we're not quiet there yet. I need R to be a variable and not a reporting parameter.
The adaptive family(family2) from ToanDN is working as I need it to be. But there is a problem with the adaptive family, I can't make the category a mechanical equipment, what I need it to be. And Revit doesn't allow for an adaptive family to be nested in a mechanical equipment family.
@ToanDN the family1 you made, isn't totaly working. When I adjust parameter AA, the bend doesn't move.
Message 7 of 12
Alfredo_Medina
@Anonymous , If the Family2 that ToanDN posted is working, then, simply reproduce that family in a mechanical equipment family, and please mark his post as the solution.
Message 8 of 12
@Alfredo_Medina, I can't reproduce the family2 from ToanDN in a Mechanical Equipment family, because adaptive extrusion is not support in a mechanical euiqpment category.
Message 9 of 12
Alfredo_Medina
By "reproduce" I mean : make again the same reference planes, parameters, etc, in a generic family, mechanical equipment category. I did not say load, but "reproduce", repeat.
Message 10 of 12
@Alfredo_Medina, your solution is tried bij ToadDN, in family1, where the bend doesn't move with parameter AA. I Have the same problem. In family2 a form element is used, where apparently it will work. But a form element I can not load in mechanical equipment category family.
Message 11 of 12
Alfredo_Medina
You keep saying that you cannot load Family2 into a mechanical equipment family.
You have already received 95% of the solution to your problem. Please do the remaining 5%, which is to reproduce the same geometry and parameters in a new family.
Message 12 of 12
I just tested family 1 and it works as intended.  Try the attached file again.
