Extrusion doesn't follow the path in Massing
drenL5229
Message 1 of 8
drenL5229
I am trying to create a curved path so that I can extrude a round extrusion. For some reason when I create a solid (after selecting the circle profile and the path) it just does a straight line!
It did create a curved line one time, don't know how, but now I can't get it to work. The curved line is hosed on a reference line since I want to be able to control the angle.
Attached are 2 pictures that better show the problem.
Thank you!
Replies (7)
Message 2 of 8
constantin.stroescu
it looks like instead of a Sweep you 've created a Loft using to circles placed on points 1 and 3...(see min 1.34 of my screencast )
https://www.youtube.com/watch?v=dbTPWcuDq6w
Constantin Stroescu
Message 3 of 8
drenL5229
Hi @constantin.stroescu ,
Thank you for the video. Unfortunately it isn't working. I attached another picture. I just want to create a form from the 2 "triangular" shapes and the path that connects them.
How would I go about doing that since it is just not working.
p.s. adding another picture. I want to have this form follow a curved path (slightly curved).
Message 4 of 8
drenL5229
The two "triangular shapes don't reside in the same plane. So maybe my question would be, how to create a form that links 2 profiles (closed or open) with a line that has a curve and is not just straight.
Also, I don't want to create profiles and host them at the end of the paths, since I want to have the ends of it be at a particular angle and not just perpendicular to the path.
Thank you, I appreciate your time!
Message 5 of 8
constantin.stroescu
make a Loft and then use a Profile and Edit it as shown in the screencast:
https://www.youtube.com/watch?v=mybPPQOfFHw
Constantin Stroescu
Message 6 of 8
drenL5229
Thank you!
I don't know why you can't just add the path s you have more control, but I guess it does the trick.
Message 7 of 8
constantin.stroescu
another method by using Loft - 3 Lofts on your path..
https://www.youtube.com/watch?v=aigMiDgwSA4
Constantin Stroescu
Message 8 of 8
another way to do the Form by using Profiles perpendicular to the Path:
https://www.youtube.com/watch?v=NE3ynljri0Y
Constantin Stroescu
