Exterior Walls
Exterior Walls
Exterior Walls
Where can I find the walls to load from the US Imperial Folder?
Create a new project from the Architectural template (or open the template directly), then switch to your project and go to Manage > Transfer project standards > Walls to transfer them from the template to yours.
(Walls are system family so they do not exist as external families in the library lie doors or windows.)
how to find the exterior-10" concrete wall?
That's it? Just edit a Generic type, change Function to Exterior, edit Structure, change Thickness to 10" and material to Concrete.
There are no System Families, such as Walls, Floors, Roofs, etc., in the Library.  What the Library contains is Loadable Families -- a whole different animal.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
FWIW:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
ennujozlagam
it could be libraries and template are not installed, you can refer to this LINK and see if helps. thanks
hmunsell
if you have a project that already has that wall in it, do a Transfer Project Standard.
  • open the file that has the desired wall
  • Manage ribbon > Settings > Transfer Project Standard
  • pick the file from the list
  • pick CHECK NONE!
  • scroll down the list and pick the Wall Type option
  • select OK
 this will transfer all the wall types from the selected file into yours.
Howard Munsell
