We have always worked in AutoCAD and more recently JDA Floor Planning... my company is currently looking to put something in Revit. We have full access but no training.
We have a building file in Revit from an architect but cannot get this to export. When we press export we get a couple of options 'energy mode' etc. but this will not progress based on their being no 'rooms'
When we go with the other option, no fixtures are on the plans (walls and signage only) and export is greyed out.
Does anyone have any very basic knowledge on how we can get this to work. We are currently just trying to test the functionality
Any help appreciated
you can start learning from this tutorial, you can refer to this LINK. thanks
Are you trying to export a Revit model to AutoCAD? If so, go to File Menu, Export, CAD Formats. There is DWG option there where you can export your Revit model to CAD.
File > Export > CAD Formats > DWG
once there you can select the view(s) to export. mine is highly customized to my company standard, but i think the default settings are AIA standard.
Howard Munsell
Could you perhaps elaborate on what you're trying to achieve? If you have full access to Revit, where do you need to export to? Is it JDA Floor Planner? Do you need this? Does this software not accept DWG files? Maybe try as an IFC export rather.
This link may help you. It also seems to suggest that a DXF file can be opened in JDA Floor Planning. You can export directly as a DXF from Revit.
