Hi guys,
Does anyone know if Revit 2020 runs under Windows 10 Home edition? In the system requirements page here
says that Windows 10 Enterprise & Windows 10 Pro are supported, without mentioning Windows Home, which seems a bit odd.
Thank you in advance.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Yeah, that is odd. I just looked at the specs for Home, and I don't see why it was omitted. Give your reseller a call to confirm -- or Autodesk via your account portal.
Thanks for your answer, barthbradley. I've installed Revit LT on Windows 10 Home Edition and it works fine.
Please I need help, I have 20G of free storage on desk C and Windows 10 home, But at the installation part, the can't click "install" in the window of revit and i cant click on brows to choose file install location neither. what I noticed tho is when I go back and choose install tools and utilities instead of install I can click in this case on "install" BUT, not everything is checked " Revit Server " that shares project ext won't be installed. What can I do ???
