exterior partial height tapered stone veneer
8 REPLIES 8
Message 1 of 9
mattV87CE
1225 Views, 8 Replies
ok, I have been searching and playing around and cant fig this out. I have a generic exterior wall. I want to add a partial height tapered stone veneer to the exterior of the wall. I tried several methods, but want to make sure I do this correct the first time. Any recommendations or places to look for the info would be greatly appreciated. Would a wall sweep work? The tapered overlay would be 14' tall, 11" at the base and 3" at the top (roughly). Thank you in advance!
8 REPLIES 8
Message 2 of 9
in reply to: mattV87CE
Message 3 of 9
mattV87CE
in reply to: barthbradley
attached is a snippet of what im trying to create. I did an in-place-wall, but I dont like the functionality as it wont mitre the corner. I will add a stone finish when I'm done with the model.
Message 4 of 9
I'd probably do it as a sweep too.  It's a valid approach.
Message 5 of 9
mattV87CE
ok, ill give it a shot again. I've been away for 2 weeks and am creating my custom profile the way I remembered doing it before. and when i load my 14'-0" high "stone veneer" profile it just shows a small square. Im sure I am just forgetting something stupid. Thank you and have a good day!
Message 6 of 9
Create a family from Profile-Hosted family template, draw a shape of 14' tall, 11" at the base and 3" at the top, load it in your project, edit a Wall Sweep type and give it that profile, draw the wall sweep by picking walls.
Message 7 of 9
Odd. If that happened to me, I'd first think that the Profile in the Project was not the correct one.  Did you modify profile and forget to reload?
Ah! Maybe @ToanDN 's onto something.  The Sweep Type may be using the wrong profile.
Message 8 of 9
mattV87CE
may very well have done that.
Message 9 of 9
mattV87CE
Thank you Sir. Came in fresh today and made a wall sweep and it worked perfect. I was forgetting one little step. Have a good day!
