ok, I have been searching and playing around and cant fig this out. I have a generic exterior wall. I want to add a partial height tapered stone veneer to the exterior of the wall. I tried several methods, but want to make sure I do this correct the first time. Any recommendations or places to look for the info would be greatly appreciated. Would a wall sweep work? The tapered overlay would be 14' tall, 11" at the base and 3" at the top (roughly). Thank you in advance!
Solved by ToanDN. Go to Solution.
A wainscot? Stacked Wall would be one approach.
...yes, sweep would work too. You could build it into the wall assembly.
attached is a snippet of what im trying to create. I did an in-place-wall, but I dont like the functionality as it wont mitre the corner. I will add a stone finish when I'm done with the model.
ok, ill give it a shot again. I've been away for 2 weeks and am creating my custom profile the way I remembered doing it before. and when i load my 14'-0" high "stone veneer" profile it just shows a small square. Im sure I am just forgetting something stupid. Thank you and have a good day!
Thank you Sir. Came in fresh today and made a wall sweep and it worked perfect. I was forgetting one little step. Have a good day!
