Extending Stringer
Extending Stringer
awadsworth8Q4WM
Extending Stringer
awadsworth8Q4WM
There has got to be a way to extend the stair stringer.  I have looked everywhere and cant find anything.  See attached picture.
Tried these settings?
awadsworth8Q4WM
I have those settings.  The problem is the stringer cuts off at bottom stair nose. (Attachment pic 1).  What I need to happen is the stringer extends past the bottom stair nose at least 7". (Attachment pic 2)
ennujozlagam
you need to separate profile of your stringer together with your railing or separate stringer and railings to achieve this. thanks
_Vijay
in the END only you can not change the profile ….try with inplace in the end only. refer below snip may be it will help you.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Untick Begin with Riser
