Hello Everyone,
I'm having this problem that I have never encountered in Revit before:
As shown in the screenshots, the hidden edges appears and they print too which is the main concern!
I looked everywhere for an answer but I didn't find any.
Also, this is not a hardware graphic problem as it appears in everyone computers (it is not central file too, but every student who opened the file have the same problem)
Any Help please ? We have a deadline to produce diagrams this Coming Tuesday and this is an issue.
Thank you very much!
Solved by barthbradley. Go to Solution.
Solved by ToanDN. Go to Solution.
@barthbradley Thank you for replying.
Do you mean re-posting the problem again as a reply to you?
@Anonymous wrote:@barthbradley Thank you for replying.
The File...so we can see how it was modeled.
No, just post it here. Let anybody that wants to, check it out. More the merrier.
Okay i'm trying a google drive link I hope this will work:
https://drive.google.com/open?id=17lAUQ-RCdNnxDIBG50qWcc3L2U7zT1f-
You have some elements far, far away from the Internal Origin (a.k.a. The Project Base Point's Startup Location). Revit has a 10 radius limit.
When geometry is far away from the model's internal origin, the graphical representation of elements becomes less reliable and less accurate.
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-3F79BF5A-F051-49F3-951E-D3E86F51BECC
Glad my work was able to point everyone in the right direction.
I didn't know it was necessary to actually provide a file back to you. Deleting is the easy part. Window-Select, Delete. But WTF am I deleting? Critical information? Only you could determine that.
Here's what was deleted:
@barthbradley Actually that element is a copy from an existing GM I already have in the right location! Thanks so much for pointing this out thought! I wasn't aware that it was somewhere in the model causing all that problem. Thank you to everyone who helped me !
