Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
EXTENDED LINES IN 3D VIEWS PROBLEM
14 REPLIES 14
Message 1 of 15
1296 Views, 14 Replies
Hello Everyone,
I'm having this problem that I have never encountered in Revit before:
As shown in the screenshots, the hidden edges appears and they print too which is the main concern!
I looked everywhere for an answer but I didn't find any.
Also, this is not a hardware graphic problem as it appears in everyone computers (it is not central file too, but every student who opened the file have the same problem)
Any Help please ? We have a deadline to produce diagrams this Coming Tuesday and this is an issue.
Thank you very much!
14 REPLIES 14
Message 2 of 15
Let's take a look at it. Post it here.
Message 3 of 15
in reply to: barthbradley
@barthbradley Thank you for replying.
Do you mean re-posting the problem again as a reply to you?
Message 4 of 15
The File...so we can see how it was modeled.
Message 5 of 15
No, just post it here. Let anybody that wants to, check it out.  More the merrier.
Message 6 of 15
i'm not sure why my post with the attached file is not published!
Message 7 of 15
Okay i'm trying a google drive link I hope this will work:
https://drive.google.com/open?id=17lAUQ-RCdNnxDIBG50qWcc3L2U7zT1f-
Message 8 of 15
You have some elements far, far away from the Internal Origin (a.k.a. The Project Base Point's Startup Location).  Revit has a 10 radius limit.
When geometry is far away from the model's internal origin, the graphical representation of elements becomes less reliable and less accurate.
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-3F79BF5A-F051-49F3-951E-D3E86F51BECC
Message 9 of 15
See revised file when I deleted some remnant elements too far from the main model.
Message 10 of 15
in reply to: ToanDN
Thank you so much for your Help!
the edges are fixed !
Thank you everyone for the provided Help!
Best,
Message 11 of 15
Glad my work was able to point everyone in the right direction.
I didn't know it was necessary to actually provide a file back to you.  Deleting is the easy part. Window-Select, Delete.  But WTF am I deleting? Critical information?  Only you could determine that.
Here's what was deleted:
Message 12 of 15
@barthbradley wrote:
Glad
I am glad that you are glad.  And you are welcome.
Message 13 of 15
in reply to: ToanDN
You poking the bear, @ToanDN? "@barthbradley wrote: 'Glad'"?  I see you are again "Repackaging".  You can't help yourself, can you?  There are 12-step programs that can assist you.   FWIW.
@Anonymous:  Need any of these elements that @ToanDN blew out of your Project?  They look pretty important to me.
Message 14 of 15
So you said you were glad but you actually weren't? That's sad. Still, you are welcome.
Message 15 of 15
@barthbradley Actually that element is a copy from an existing GM I already have in the right location! Thanks so much for pointing this out thought! I wasn't aware that it was somewhere in the model causing all that problem. Thank you to everyone who helped me !
