I have a railing family whose lower constrain should match the lower edge of landing and run as the red line in sketch. and then the top of the floor.
I tried with different rail family for landing and stair run but the joint is a problem.
Any idea how I should proceed?
Gelöst! Gehe zur Lösung
Gelöst von martijn_pater. Gehe zur Lösung
You can use landing height adjustment. edit: doesn't do the trick, it will require some more tweeking to baluster bottom/top to rail and host then I thought...
Landing Heigh adjustment property
hmmm here's what I'm thinking atm, which is you need to do panels if you don't want to have the height correction for the (top) rail: https://www.autodesk.com/autodesk-university/class/Designing-Custom-Railing-Panels-Revit-2017
Hi @prasadienator,
Thanks for posting. It looks like the AU class shared by @martijn_pater may help, did you get a chance to try it?
If the suggestions helped you, please hit the "Accept Solution" button, as it helps makes the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you. ![]()
@barthbradley(How) did you keep the rail height at 1m on the landing? It's a lot easier not to do so (possibly way to go...) But if it should remain at 1m on the landing, perhaps you've found the setting I'm overlooking...
Yes Yes Yes!!! @barthbradley
How were you able to maintain 1m on top? Am I missing out on something obvious?
I would nevertheless watch the AU video @martijn_pater sent. and learn more.
Thanks a lot Barth, Martijn!
@prasadienator wrote:Yes Yes Yes!!! @barthbradley
Make your rail from one continuous sketch line and use the settings shown in the screenshot I posted. Bada Bing.
I had tried like that before.
my top of the rail is not 1m frm finish anymore. I am gonna go through the video Martijn sent and try get a hang of how to control top of the rail independently.
Thanks again. ![]()
So, tried to get you started on a panelling solution if not already. It's a bit more trickier then you want it to be tbh. Anyway, in the process I figured out you could sort of force such a panel using a nested generic family, setting it as start post which sort of forces it in position, which is a neat trick I suppose... 'panel' height in railing just needs some value other then 0 just to get that working with a nested family... But honestly it's easier to model in-place, or nest in-place in railing category (or possibly use curtain wall as railing)...
Stair railing using panelling, railing 1m continuous on landing
curtain wall was my last resort.
in-place is not feasible, its a mid-high rise with different floor heights and 3 staircase cores.
I will study the material I already found on AU and the nested generic family. Eventually I will post it here.
Thanks a ton! have a good week!
