Could somebody please tell me how to correct this wall join
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
NickMcGilvray3520
377 Aufrufe, 4 Antworten
It`s driving me crazy!!!!!!!!!!
I`ve tried everything I can think of but I can`t get the walls to walls to join properly.
Thank you
Nick
4 ANTWORTEN 4
Nachricht 2 von 5
syman2000
als Antwort auf: NickMcGilvray3520
You have to make sure the CMU is not structure in the other wall. Sample below shows hierarchy layering. If concrete is the structure and you have CMU set as structure as another wall, it will join structure with structure. To overcome this you make the CMU as secondary and the other CMU as secondary as well. When you join together, it will clean up properly.
Nachricht 3 von 5
Nachricht 4 von 5
lim.wendy
Hi @NickMcGilvray3520
Welcome to the forum! I wanted to reach out and see if you were able to get your issue figured. It looks like ‌both @barthbradley and @syman2000 provided some good suggestions.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps makes the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you. :leicht_lächelndes_Gesicht:
Let us know how things are going!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Nachricht 5 von 5
Problem Solved.
Thank you.
