Exporting interior walls to dwg I-Wall Layer
9 REPLIES 9
Message 1 of 10
526996629
543 Views, 9 Replies
Does anyone know how to export interior walls to dwg I-Wall layer rather than A-Wall layer?
I have set the so-called 'interior walls' function to 'interior'
However, when exporting this to dwg, this type of wall is still in the A-Wall layer. Any suggestions? Thanks.
Labels (1)
  • I
9 REPLIES 9
Message 2 of 10
in reply to: 526996629
Are you sure the Walls/Interior export to "I-Wall" Layer under Export Setup?
...post screenshots of your Export Setup.
Message 3 of 10
526996629
in reply to: barthbradley
Thanks for the replay. Please see image below:
I think all walls are set to the 'Walls' category. Any way to drop the interior walls to 'walls/interior' category?
Message 4 of 10
jmhanbyV4TDM
What is the Function - Core-Shaft set to?
When I exported the gypsum finish went to the I-Wall layer and the core of the wall went to the A-Wall layer.  Try to set the core-shaft to interior and see what that does.
Message 5 of 10
526996629
in reply to: jmhanbyV4TDM
Sorry, but this way is not helping.
Message 6 of 10
Post your file
Message 7 of 10
526996629
Please see attached. Anything wrong with my export setup? Or any other reasons?
Message 8 of 10
No issues with the File.
Message 9 of 10
FWIW: I opened your file with Audit and Detach from Central checked.
Message 10 of 10
526996629
Thanks for you reply.
Did you use my export setting called 'dwg export'?
Also, I had the same wall type here in the image. But when exported to CAD, they are dropped in different layer. One is in the A-Wall layer and the other is in the I-Wall layer. What is the reason?
I copied these 2 walls into the same file I send you just now.  Below is what happens. A possible reason is something is not correct in my export setting. But I didn't find out. (I attached a new one that shows the image below.)
Tags (1)
Forma Design Contest
