Exporting IFC from Revit: Walls don't attach to roof
03:42 AM
- Mute
- Permalink
- Report
Hi everyone,
I am trying to export an IFC from a Revit model including four curved walls and a sloped roof. All the walls attached completely fine to the sloped roof in Revit but:
- As soon as I export the Revit file as IFC and open it in Solibri, the wall becomes unattached to the roof or at least it looks like they are unattached. (image 01)
- The roof’s corners where I have slop arrow do not show, as they should. (image 02)
I have tried same IFC file in Navisworks and I have the same issue with same IFC file there as well. However, it works completely fine when I export a NWC from the same Revit file (Image 03)
I have tried to use Void Form to cut the upper part of the wall, which did not help either.
I assume it should be the IFC settings; I have tried different settings, unfortunately I could not find anything to fix the problem.
I was hoping that I could get some tips or suggestion here. Any help would be very appreciated
