How to make these chinese roof tiles?
Message 1 of 19
Replies (18)
Message 2 of 19
Alfredo_Medina
It can be done with reference points, splines of three points, surfaces, and a pattern-based family for the tiles. Not necessarily with Dynamo as shown in the picture. To get started, study the attached handout. It's from a class I gave in 2013 for the RTC conference in New Zealand.
Message 3 of 19
aRcHiTeCt.JM
I made this couple of years ago.
at that time was more less copy paste each tile
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 4 of 19
So all I have to do is make the tiles in adaptive component family and use it as pattern for massing surface like this?
Message 5 of 19
Viveka_CD
Hi @Anonymous
I came across this interesting blog post which has a step by step technique to design this roof.
Let us know how it goes and if are looking for more information! @Alfredo_Medina is one of the best for adaptive design.
Message 6 of 19
Viveka_CD
Hi @Anonymous
Here's a youtube video on Adaptive Conical Roof with Tiles, Spanish roof tile, Clay tile roofing
Message 7 of 19
All HyunWoo Kim's stuff is amazing. Almost as good as @Alfredo_Medina's stuff.
Smiley Wink
Message 8 of 19
What does this error mean?
Message 9 of 19
Viveka_CD
@Anonymous
What error is displayed when you hit 'expand'?
Message 10 of 19
Message 11 of 19
Viveka_CD
Hi there @Anonymous
Can you share the family or Revit file to test further?
I can send you a private folder to upload.
Let me know, I look forward to your reply.
Message 12 of 19
Have you tried flexing "Family 7" (and/or the family it's nested in)?  Betcha you can't without breaking it.
Message 13 of 19
For some reason,I am not able to post reply after attaching the file.The page just keeps on refreshing
Message 14 of 19
Viveka_CD
@Anonymous
Please try with a different browser, sign out and sign in again and try attaching the file again.
Message 15 of 19
Here is the file.
Message 16 of 19
Viveka_CD
Hi @Anonymous
Thanks for sharing the family.
Were you able to try the recommendations in the above posts?
Message 17 of 19
yurikim
Thank you @Anonymous for your post. This error means constraints are not met.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
When you place this roof tile, points that you select needs to be according to the adaptive points from family10. You might want to simplify the constraints by removing some of the adaptive points.
Yuri Kim
Product Support Specialist, AEC
Message 18 of 19
@Anonymous: do you know that you can download a family such is this?  Perhaps reverse-engineering one of the barrel shaped tile families available on-line would be the easiest way to learn.  BTW: I've never heard of them referred to as "Chinese". Usually, "Spanish", because it's the archetypal shape of the terracotta clay roofing tiles used on Spanish missions.
http://www.arcat.com/bim/eagleroo/Roof-Tile.shtml
Message 19 of 19
@sayoo.jay Do you got making these chinese roof? Or anybody could show how modelling?
