Wall finish height
5 ANTWORTEN 5
Nachricht 1 von 6
3740 Aufrufe, 5 Antworten
Wall finish height
Is there any way to end the finish of a wall in a specific height?
For example, I have a bathroom wall with ceramics up to half of the wall height.
Thanks!
Amit
5 ANTWORTEN 5
Nachricht 2 von 6
zemeraloni
als Antwort auf: Anonymous
Hi @Anonymous
You can create a stacked wall or create to types of walls the one of then is only the finish itself.
Nachricht 3 von 6
Nachricht 4 von 6
Edit Assembly for the compound layered wall, and unlock the pad locks on the finish material layer. You do that through a section view and using Modify in Edit Assembly mode.  Once unlocked, you will have an additional parameter available under the Wall's Instance Properties that you can enter a negative or positive extension value.
 ...sorry @Anonymous, I think I misread. You want to use Split Region to create a Finish Layer of Variable Materials
Nachricht 5 von 6
cbcarch
Most of these may have already been mentioned, but--
-One way is to model a separate thin tile wall, placed over the backup wall--just like in the real world.
  Use Join Geometry to cut at door/window openings if required.
-Split-Face and Paint a Material is another way, but be careful as wall join edits can "delete" the split faces.
- Stacked Wall is another possibility
- Unlock compound wall layer and drag it up/down is another method.
- Use Parts, Divide Parts and then apply a different material is another more complicated method.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 6 von 6
als Antwort auf: cbcarch
...Got another: say your tile wainscot is 54" high x 1/4" thick -- then you could apply a wall sweep using a 54" x 1/4" Profile.
