Exporting elements to IFC as "fine" but not as "Coarse"
a.aroesti
Message 1 of 14
a.aroesti
Hey.
could I somehow "force" export to IFC all elements as "fine" although they are defined in the family editor as "Coarse"?
Replies (13)
Message 2 of 14
Create a Fine view, VGO the category to Coarse, and open it when export to IFC with these settings.
Message 3 of 14
RSomppi
You would have to edit the family.
Message 4 of 14
a.aroesti
@ToanDN I tried it before and it didn't work.
@RSomppi  for sure? did you try it before? is it possible to convert the Revit file itself but not a specific view?
Message 5 of 14
RSomppi
What? I don't understand. More words, please.
Message 6 of 14
a.aroesti
I'm asking if you tried to do the same in the past and didn't find a solution.
and add one more question: is it possible to export the whole model but not a specific view?
Message 7 of 14
Message 8 of 14
a.aroesti
@ToanDN
look at this...really weird behavior...
one PS is from IFV Viewer and the other from Revit.
maybe because you are using a generic model?
one more thing: on the visibility graphic when Im choosing "coarse" it looks like this and when I'm choosing "fine" i can see only the symbol.
Message 9 of 14
Share that family here.
Message 10 of 14
a.aroesti
Attach
Message 11 of 14
Do you see it in this IFC?
Message 12 of 14
a.aroesti
Yes, I can see it on IFC
can you share the Revit model?
what setting did you choose for exporting to IFC?
Message 13 of 14
Nothing special about the Revit file and I deleted it already.  I created a new project from 2022 System Template, inserted you family and placed it on a pipe.
Message 14 of 14
a.aroesti
@ToanDN
Thnaks, i needed to check "export only elements visible in view" .
very weird behavior.
