I have 4 projects (2 projects & 2 project templates) in Autodesk Docs.
From the Home page of Revit 2022, I can see them all.
From the Home page of Revit 2023, only 2 of them show up. How do I get the missing Autodesk Docs 2023 project to show up in the Revit 2023 Home page, so I can access the files from there?
Solved by Yien_Chao. Go to Solution.
in 2023 you can reach the templates i believe?
keep in mind:
1. the model must be a cloud collaboration to appear in your Revit menu.
2. each Revit version can only see their project's version on cloud.
3. once you update a cloud version, you cannot go back.
let me know
Thanks for the quick response. I have no cloud collaboration models in any of the projects, so what I am seeing is just the file structure of the project, without any of the actual files. I just thought this was a shortcut to get to Autodesk Docs projects, but it really is only for collaboration models, so I just need to stick to the Browser, & access the ACC files from there. In 2023 one of the 2 files was a template & the other not, but since I can't get to non-collaboration models from here, it is a mute point.
