Exporting DWG issue
Exporting DWG issue
ellie7XSRV
Message 1 of 24
Exporting DWG issue
ellie7XSRV
So it every time I go to export a DWG file, there are random things missing.  For example, there is a big chunk of a wall missing, entire walls missing, doors missing, random components missing (there will be one of the exact same thing on the cad and one missing).  I've attached screenshots from the DWG where you can see there are definitely missing spots and a Revit one to see what is missing (one this a missing chunk in a wall - that is one single wall, some doors and equipment are also missing).  I will have to comment to add more attachments.
Replies (23)
Message 2 of 24
ellie7XSRV
Here are more screenshots - this one there is clearly equipment missing (along with walls).  It is strange, there are two exact same tables, one is showing up and one is not.
Message 3 of 24
Screenshot your Export Settings.
Message 4 of 24
ellie7XSRV
here is a screenshot
Message 5 of 24
That's one tab. What about the others?
Try using <in-session export setup> and report back your results.
Message 6 of 24
ellie7XSRV
Hopefully the zip file works since there are so many screenshots
Message 8 of 24
Message 9 of 24
ellie7XSRV
Nope, neither of those worked.  I tried checking "preserve coincident lines" and "export views on sheets and links as external references" at the same time.  I tried just check one and then the other.  Same result.  Still have missing chunks/walls/equipment/etc..
Same thing happens when I export with "<in-session export setup>"
Message 10 of 24
Post the File. If I can replicate, then I can figure it out.  Otherwise, it's just a guessing game -- and frankly, I'm out of guesses at the moment.
State your software versions as well.
Message 11 of 24
syman2000
I run into the same issue yesterday where my annotation text from Revit won't get exported to AutoCAD. I was able to export out successfully opening new project and link in your existing Revit model.
Here you go to the Revit link and then link by view to your plan. Then Export it out and my CAD export out with proper text.
Message 12 of 24
ellie7XSRV
Nope, I tried your method where you link the project in and export from there.  Same result as before
Message 13 of 24
ellie7XSRV
here's the project.  I purged all unused and got rid of extraneous views that I don't need to export,  It's in Revit 2020
Message 14 of 24
syman2000
I've look at your file. One question I have is rehost the door elsewhere and seeing these wall in limbo eventhough the wall phase and door has the same phase created and demolished. Without knowing the history of the file, can you explain if there was design option placed on the file?
When I remove the wall and export them out it works partially but still issue persist. However I found a quick solution to export it to CAD. Print them as PDF. Then in AutoCAD, you can import PDF and convert to CAD
Message 15 of 24
ellie7XSRV
There is no design options for the file.  I will try and do the work around and import a pdf into cad
Message 16 of 24
I can't replicate an issue -- at least in 3 tests - using your export setup. What View(s)/Sheet(s) are you Exporting?  Or, do you see something I'm not seeing between in these two screenshots?
Message 17 of 24
ellie7XSRV
huh, now I am really confused.  Why are you not having the same issue? I tried to export from that exact file and had the same issues I did before
Message 18 of 24
Give me your particular workflow to replicate.  For Instance, start with the name of  the View you were unsuccessfully Exporting.
Message 19 of 24
ellie7XSRV
I am trying to export the Demolition Plan sheet, the Floor Plan sheet, the Equipment Plan Sheet, and the Reflected Ceiling Plan Sheet
Message 20 of 24
ellie7XSRV
So I just tried to export the floor plan view and it worked just fine, so it has something to do with the sheet
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
