Hi I am doing a project and I was wondering how to make it so a curtain wall is shown in the floor plan view level 1. I used a curtain wall to make a cut in the middle of a wall. My instructor has his cut shown in the floor plan view but I am not able to get it to show up. I am wondering if there are any tips on how to get it to show? Kind of urgent. The red circle is where the curtain wall should show up to view it.
Thank you!
Thank you!
Is the Window being cut by the View Range Cut Plane? Is the View set to the correct Phase?
...here a list you may want to keep handy for occasions like this:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Is your curtain wall drawn in the correct phase? (and/or the view phase set correctly as @barthbradley suggested)If its above your general view cut plane, you could use a plan region. edit: although true, I figured this might be confusing. so scratch that.
