Exporting DWG issue
Exporting DWG issue
ellie7XSRV
Message 1 of 24
Exporting DWG issue
ellie7XSRV
So it every time I go to export a DWG file, there are random things missing.  For example, there is a big chunk of a wall missing, entire walls missing, doors missing, random components missing (there will be one of the exact same thing on the cad and one missing).  I've attached screenshots from the DWG where you can see there are definitely missing spots and a Revit one to see what is missing (one this a missing chunk in a wall - that is one single wall, some doors and equipment are also missing).  I will have to comment to add more attachments.
Replies (23)
Message 21 of 24
syman2000
Remove this legend and see if the export works. I did it at my end and it seems to be the culprit
Message 22 of 24
ellie7XSRV
Yup that worked on my end.  That legend was the culprit. Not sure why but that's not important we just use it to line things up across all of our sheets.
Message 23 of 24
You don't need to get rid of the legend view.  Simply adding a couple of drafting lines at the corners of the view will fix it.
Message 24 of 24
CarlMaxey3179
Exporting interior elevation sheets from revit into autoclod doesnt work well at all.  the room boundaries cannot be exported.  the work around is to offset the view boundaries which makes the interior elevations look like crap.  Hey Autodesk, fix this please.
