Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Exported images not scaled
8 REPLIES 8
Message 1 of 9
1841 Views, 8 Replies
Hello everybody.
I have a problem exporting the facades of my project, Revit doesnt give me scaled images. I adjusted all the facades to be 1/200, I,m attaching the files.
8 REPLIES 8
Message 2 of 9
You exported? To what?
...and what did you export?
Message 3 of 9
in reply to: barthbradley
I exported the FACADES to jpg (Image File)
Message 4 of 9
...what are you opening/measuring it with?
Message 5 of 9
awes
What do you mean by not scaled? Are you printing those jpg:s on paper?
Message 6 of 9
Look it, if you are looking for accurate scaling, then print  it to PDF at 100% (no scale) and then print the PDF.
Message 7 of 9
I tried also to print them to pdf, the problem is that I need all the stuff to put it into a Photoshop file. When I put it into photoshop they became bigger.
In autocad for example, I can print (making PDF) a drawing to a A2 or A3 paper and after that I transfer it to photoshop and 0 Problems.
Message 8 of 9
RobDraw
You just stated a solution.
Rob
Message 9 of 9
If you want paper size then place the view in a sheet of the paper size you want, A3 or A2 or whatever, then print the sheet to PDF at 100%. Open the pdf in Photoshop and it is the size it is.
With that said, if you have Photoshop then you can export the view directly to a image format, choose the resolution of your choice, then resize resample it in photoshop.
