How can I give line thickness difference? in elevations
Turn Thin Lines Off
tkanks but I did not mean it. The thickness of the pencil does not give a difference. all lines have the same thickness when I remove them from the printer
I'm not following. Is your model using different Line Weights?
revit sections gives automatic line thickness,
not in views
That's not true. Or maybe I don't understand what you are saying. Can you elaborate?
...the View Scale is dictating line weight. Jack up the Line Weight in the View or change the View Scale.
