Export to gbXML
4 REPLIES 4
boutheynamzoughui
764 Views, 4 Replies
Export to gbXML
Hello ,
I'm trying to export from Rvt to gbXML, to import it then into Dialux but every time it shows locked like the picture below ,
any one knows why ?
4 REPLIES 4
dzanta
in reply to: boutheynamzoughui
Verify the following before issuing the gbxml export command:
1.  Spaces/Rooms are created and vertical boundaries are satisfied
2.  Ensure volume is set to calculated within Areas and Volumes Settings
3.  Verify in Details Tab, no errors present...fix any visible
4.  Follow the guidelines here:
     https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
I'm pretty sure you need to be in a 3D view.
Justin Doughty
Cadline Ltd.
Blog | Twitter
Yes when i opened 3D view , it unlocked
Thank you Mr Justin Doughty ^^)  ,
boutheynamzoughui
in reply to: dzanta
Thank you , the link was useful ^^)
Forma Design Contest
