Hello ,
I'm trying to export from Rvt to gbXML, to import it then into Dialux but every time it shows locked like the picture below ,
any one knows why ?
Solved by Justin_Doughty. Go to Solution.
Solved by dzanta. Go to Solution.
Verify the following before issuing the gbxml export command:
1. Spaces/Rooms are created and vertical boundaries are satisfied
2. Ensure volume is set to calculated within Areas and Volumes Settings
3. Verify in Details Tab, no errors present...fix any visible
4. Follow the guidelines here:
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Yes when i opened 3D view , it unlocked
Thank you Mr Justin Doughty ^^) ,
