Export Steel Structural Connections
1 REPLY 1
289 Views, 1 Reply
Hello, i have quite a problem, after several days of work i realized all the steel connection in the model disappeared. Luckily i have all of them in an old file....there is a way to transfer the connections from the old file to the newer file?
1 REPLY 1
chrisplyler
Link the old file into the new one. Then Bind the linked file, which converts it from a Link to native elements.
I recommend that prior to performing that, you make a copy of the old file, and delete everything that you DON'T want to bring into the new file, then Purge everything you don't need. Then save it and use this simplified file in the above process.
Forma Design Contest
Technology Administrators
