Link the old file into the new one. Then Bind the linked file, which converts it from a Link to native elements.
I recommend that prior to performing that, you make a copy of the old file, and delete everything that you DON'T want to bring into the new file, then Purge everything you don't need. Then save it and use this simplified file in the above process.
