Export section view from revit to dwg file with Internal Origin in the Coordinate Base, but elevation value (y-axis) are not correct.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi , when I export section view or 3D model to dwg, then using Internal Origin in the Coordinate base (Units & Coordinates" tab), but when I check in dwg file, then the elevation are not correct, like this one
1. in revit this level locate at 57.000
2. but in dwg file, I check by ID command, then i got Y=62.00, it should be 57.00, I don't know why like this.
