Hatch pattern Brocken
kunal_patilHKPZJ
kunal_patilHKPZJ
Screenshot 2024-12-12 124454.pngThis is broken patten..
this is from another project
can anyone help me find out what's the problem here i have tried creating new pattern but still same issue.
Simon_Weel
What if you use Transfer Project Standards to import the pattern from that other project?
edwin.prakoso
The "broken pattern" is usually caused by drawing too far away from the origin point 0,0,0. It is not because the hatch pattern is corrupt. If possible, move the drawing closer to 0,0,0. If not, you may want to use another measurement unit (like m, assuming you are using mm now).
Cheers,
Edwin Prakoso
kunal_patilHKPZJ
What if its not possible to move to 0,0,0 and i already tried can changing unit but its still the same. do we have any other solution.
kunal_patilHKPZJ
Already tried but not working.
edwin.prakoso
You can try the workaround mentioned here: https://www.autodesk.com/blogs/autocad/working-large-coordinates-in-autocad/
Cheers,
Edwin Prakoso
