Export section view from revit to dwg file with Internal Origin in the Coordinate Base, but elevation value (y-axis) are not correct.
4 ANTWORTEN 4
Nachricht 1 von 5
teerawat.pSCHYQ
194 Aufrufe, 4 Antworten
Hi , when I export section view or 3D model to dwg, then using Internal Origin in the Coordinate base (Units & Coordinates" tab), but when I check in dwg file, then the elevation are not correct, like this one
1. in revit this level locate at 57.000
2. but in dwg file, I check by ID command, then i got Y=62.00,  it should be 57.00, I don't know why like this.
4 ANTWORTEN 4
Nachricht 2 von 5
azad.Nanva
als Antwort auf: teerawat.pSCHYQ
did you check your Project Base Point in Elevation too,or just in plan?
Nachricht 3 von 5
teerawat.pSCHYQ
als Antwort auf: azad.Nanva
it already checked the project base point, it is no elevation
Nachricht 4 von 5
azad.Nanva
You can see what this mean :
Nachricht 5 von 5
teerawat.pSCHYQ
can you have a look this, if you have any suggestion for checking, please.
