Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Export section view from revit to dwg file with Internal Origin in the Coordinate Base, but elevation value (y-axis) are not correct.
teerawat.pSCHYQ
teerawat.pSCHYQ
Hi , when I export section view or 3D model to dwg, then using Internal Origin in the Coordinate base (Units & Coordinates" tab), but when I check in dwg file, then the elevation are not correct, like this one
1. in revit this level locate at 57.000
2. but in dwg file, I check by ID command, then i got Y=62.00,  it should be 57.00, I don't know why like this.
azad.Nanva
did you check your Project Base Point in Elevation too,or just in plan?
teerawat.pSCHYQ
it already checked the project base point, it is no elevation
azad.Nanva
You can see what this mean :
(view in My Videos)
teerawat.pSCHYQ
can you have a look this, if you have any suggestion for checking, please.
(view in My Videos)
