When I'm exporting a Room tag with multiple parameters, each parameter is exported as a separate MTEXT element in AutoCAD on 1 layer.
Is there a way that all parameters of 1 room tag in Revit are exported to 1 MTEXT element with multiple rows OR different parameters to different layers?
For example:
Room Tag
Room number
Name
Room type
Etc.
MTEXT in AutoCAD
Room number (row 1 in MTEXT element)
Name (row 2 in MTEXT element)
Room type (row 3 in MTEXT element)
Etc.
Solved by amarkonathala. Go to Solution.
Make sure that you are exporting Cad File in Preserve editablity
and also Make sure that all the parameters created in One single Label in the Family
