ESC key will not work in Revit but works everywhere else
100 REPLIES 100
Message 1 of 101
56732 Views, 100 Replies
So we are having a problem with revit where the esc key does not work but it works everywhere else.  It is not an adobe product as we do not use those programs.  Any ideas?
100 REPLIES 100
Message 2 of 101
Well, for the time being: clicking "Modify" will escape out too.
Message 3 of 101
in reply to: barthbradley
Well we specifically need the escape key because we have an add on for revit that uses the escape key as kind of a start button for splitting walls, etc.  Thanks though for the input!
Message 4 of 101
Sounds like you pinpointed the problem: the add-in.  Think?
Message 5 of 101
The add in is fine.  My revit and add in work perfectly it is just one of my co-workers computers that it does not work with.
Message 6 of 101
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community! Are you the 'M' from James Bond?Smiley Happy
I'm just checking back to see if this issue still persists.
Can you confirm if your co-workers have the latest updates installed for their Revit versions?
To make sure that the issue you are seeing is not something already fixed in one of the product updates, I would suggest checking the Desktop App to see if there are any Revit updates available. For information on using the Desktop App see the following article: About the Autodesk Desktop App
Please let me know if you seek more assistance.
Looking forward to your reply.
Message 7 of 101
JOfford_13
in reply to: Viveka_CD
We have a user experiencing this issue right now with Revit 2019.2
Message 8 of 101
Viveka_CD
in reply to: JOfford_13
@JOfford_13
Can you try a complete reboot, relaunch Revit and check if the issue is resolved?
Message 9 of 101
JOfford_13
Restarting the machine did resolve the issue but does take a lot of time, especially when you have to re-open large projects after rebooting.
Message 10 of 101
Viveka_CD
@JOfford_13
Good to hear that rebooting helped.
One more suggestion is to check  your keyboard for driver updates from your device manager. (clkc update driver)
The image below shows how you can locate this:
uninstall keyboard driver
Message 11 of 101
JOfford_13
It doesn't appear to be a driver-related issue because the key still functions fine in every other program but Revit, including AutoCAD.
Message 12 of 101
Viveka_CD
Hi @JOfford_13
Are you available for  quick screen share sometime tomorrow?
Message 13 of 101
JOfford_13
We could arrange a screen share with the user(s) who experienced the issue however it hasn't been an issue since the restart and we wouldn't be able to reproduce it on the spot.  I've only heard of 2 of our employees ever running into the issue, both of which was resolved by simply restarting Revit.
Message 14 of 101
Viveka_CD
@JOfford_13
No worries, let me know if the issue comes back again!
Message 15 of 101
praa276
Hi, we experience the issue with Revit 2018 for a user and a simple close open can't be a solution.
It happend 3-5 time a week.
Message 16 of 101
JOfford_13
in reply to: praa276
Agreed this is not a solution.  Autodesk marked it a solution, not me.
Message 17 of 101
praa276
Issue is still there. Do you have any upate on this?
Message 18 of 101
Viveka_CD
@praa276
Can you check if you are on the latest updates for your Revit version?
Also, did you run a windows update recently?
Message 19 of 101
Same problem here. Viveka_CD you are not much of a help..
Restarting Revit is a quick fix but does not solve the issue.
Message 20 of 101
@Viveka_CD
Same here. I have had this issue for the last 4 years, across 3 different PCs and i'm tired of it! 3 to 4 times a week I need to stop what I'm doing and re-start Revit! often it is not only the ESC key that stops working  but the Delete key as well. Sometimes I only need to go to Outlook and start typing something and when I return to revit the issue resolves itself, other times I need to restart Revit.
Surely restarting the software cannot be a solution.
