Impossible to remove vertical line snap
9 ANTWORTEN 9
Nachricht 1 von 10
s252499
1418 Aufrufe, 9 Antworten
Hello!
I am working on a structure which has several diagonal constructional features (so, it's impossible to have the structural grid strictly orthogonal). When I need to draw a model line, I often encounter a problem that it does not snap to endpoints, but just goes vertical (snaps to vertical axis). See screenshot attached.
I tried to turn all snaps on/off, check/uncheck them, but nothing works. I don't want it to snap to ortho, only to end- or midpoints.
I couldn't find any solution on the web, everyone just says "turn off the snaps", which, as I said, does not work for me.
I would be grateful for your suggestions.
Beschriftungen (3)
9 ANTWORTEN 9
Nachricht 2 von 10
alan.johnson7YLND
als Antwort auf: s252499
Did you try right click > snap override
Nachricht 3 von 10
s252499
als Antwort auf: alan.johnson7YLND
I did, it doesn't work.
Nachricht 4 von 10
pedruccioli
Have you tried using TAB?
I often have slightly off-axis as-builts and I just press tab when trying to snap to something that's not orthogonal.
Architecture Modelling, BIM Workflows and Information Exchange.
LinkedIn
Nachricht 5 von 10
alan.johnson7YLND
I think it will always have a vertical / horizontal 90deg snap but you could try setting the snap angle you want in the Manage Tab > Snaps > Angular dimension snap increments
Nachricht 6 von 10
Nachricht 7 von 10
s252499
als Antwort auf: pedruccioli
I did, unfortunately didn't work for me...
Nachricht 8 von 10
Model lines need the be drawn on a work plane.  Do draw them free from work plane, use structural framing and turn on 3d snap, or create a mass in place and draw model lines with 3d snap.
Nachricht 9 von 10
s252499
Unfortunately this also did not work for me.
It's normal that axes snaps are present, but I don't believe there is no possibility to make a slightly diagonal element/line....
Nachricht 10 von 10
josip_zdrilicE5DGA
i encountered the same problem while modeling from point cloud, as we want to have a real as build, that is not perfect 90 degrees.
What i di is i used the angular snap, but instead of the 1 5 15 45 90 or whatever degrees, i added 1 2 3 4 5 degrees.
So the steps are much smaller in between.
Hope that helps
PS: I drives me nuts as well that u can turn off the ortho like in autocad.
