Error - Revit student version installation
Hi! I´m having problems with Revit installation, student version. At the end a message appears (archive attached). Could anyone help me with this?
Thanks a lot!!
Olá! Não consigo instalar nenhuma versão do Revit estudante. No final da instalação dá erro (conforme arquivo anexo). Alguém saberia me responder o que fazer para conseguir instalar?
Obrigada!
TravisNave
Post the log file as it will have the reason for the failure.  Without seeing it I have to guess.  It is probably a download failure.
I would recommend that you try downloading your product (Educational okay) using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
