Error on wall creation
Message 1 of 10
Thank you for this answer.
i have so many question. Why is it when create my walls, there is a warning that says None of the created elements are visible...i usually use to create walls but not encountering this. Thank you.
Replies (9)
Message 2 of 10
there could be several reasons (33 to be precise). One might be that the wall isn't within the View Range.
...actually, @treyk posted a list today of 50 reasons why something may not show up in view. It was pretty darn good. I made a hardcopy of it for quick reference.
Message 3 of 10
Richard.P.Garcia
Hi @Anonymous,
Thank you for participating Answer Day!
You can check this article: None of the Created Elements Are Visible in This View for a start. You may also want to check the view range of your plan.
Please let me know how it goes.
Please hit the "Accept as Solution" button if my post resolves your issue and give "Kudo" as appropriate.
Richard P. Garcia
Technical Support Specialist
Message 4 of 10
Did you happen to create Structure wall and have Depth selected in stead of Height?  If so, it is the reason the wall is not visible because it is drawn below the level.
Message 5 of 10
Right! I must have unknowingly selected it. Noob. Thank you guys esp @ToanDN.
Message 6 of 10
so basically @ToanDN, it isn't within the View Range --- exactly what I said.
Message 7 of 10
Richard.P.Garcia
In addition to what @ToanDN shared, there are Wall: Architectural and Wall: Structural that you can choose from. If you selected Wall: Structural, by default, the setting is DEPTH.
Thank you.
Richard P. Garcia
Message 8 of 10
Thank you for this information..this is what i have selected. Great to know this information @Richard.P.Garcia. Thank you!
Message 9 of 10
Richard.P.Garcia
You're welcome.
Richard P. Garcia
Message 10 of 10
chrisplyler
Wow... I had the 33-point list already. Printing out the 50-point list now! Thumb-tacked to the wall by my desk.
