Error message caused Revit to close happen often
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
996 Aufrufe, 7 Antworten
Every time working with every new model I have a few incidents when I get error messages - ''error occur, changes can not be saved, caused program to close, do you want save recovery file ?'' It happened so far in 3 cases - working with ''topography points'',  ''split wall'' and mostly while ''creating new material''. My Revit 2018 (after 1 message like that) was shut down completely and I could never open it again and had to download Revit 2019. So far, I could continue working in Revit 2019 even after error messages like that cause it unexpectedly to close. I can open it, so far, and continue to work on my model. But I am always worried that my Revit 2019 will shut down just like Revit 2018 and I will not be able to recover my files. How serious are those error messages? Why do they occur ? Could be the reason for that error because Revit can not stay open more then a few days and just have to be closed and opened again after computer restart ? Please help and advice ! I appreciate a lot ! Thank you !
7 ANTWORTEN 7
Nachricht 2 von 8
ennujozlagam
als Antwort auf: Anonymous
first install latest updates from autodesk, install latest updates of your graphics card driver, before opening the file tick audit and lastly clear as much possible in your manage > warnings. thanks
Nachricht 3 von 8
als Antwort auf: ennujozlagam
Thank you ! Sorry, but I do not know how to do this ''before opening the file tick audit and lastly clear as much possible in your manage > warnings''. Where AUDIT ? Please explain in steps how to clear warnings. Thanks !
Nachricht 4 von 8
ennujozlagam
before opening your file tick audit
then clear or correct warning messages.
thanks
Nachricht 5 von 8
I got to warnings window. But I don't know how to delete all those warning signs. Please explain how. Will deleting all warnings stop me from getting those error messages causing program to close ?
Also after every Revit closing like that it offers me to send report. Should I do that ?
Nachricht 6 von 8
ennujozlagam
you can refer to these LINK and LINK and  LINK see if helps. thanks
Nachricht 7 von 8
I got it ! I can not delete warnings I have to try to resolve them to keep it minimum. Thanks
Nachricht 8 von 8
ennujozlagam
you can't delete them, everything. just resolve as much as possible. nice to hear that manage to solved your issues. thanks :strahlendes_Gesicht_mit_lächelnden_Augen::zwinkerndes_Gesicht::lächelndes_Gesicht_mit_lächelnden_Augen:
