Error message caused Revit to close happen often
7 REPLIES 7
Message 1 of 8
885 Views, 7 Replies
Every time working with every new model I have a few incidents when I get error messages - ''error occur, changes can not be saved, caused program to close, do you want save recovery file ?'' It happened so far in 3 cases - working with ''topography points'',  ''split wall'' and mostly while ''creating new material''. My Revit 2018 (after 1 message like that) was shut down completely and I could never open it again and had to download Revit 2019. So far, I could continue working in Revit 2019 even after error messages like that cause it unexpectedly to close. I can open it, so far, and continue to work on my model. But I am always worried that my Revit 2019 will shut down just like Revit 2018 and I will not be able to recover my files. How serious are those error messages? Why do they occur ? Could be the reason for that error because Revit can not stay open more then a few days and just have to be closed and opened again after computer restart ? Please help and advice ! I appreciate a lot ! Thank you !
7 REPLIES 7
Message 2 of 8
ennujozlagam
ennujozlagam
first install latest updates from autodesk, install latest updates of your graphics card driver, before opening the file tick audit and lastly clear as much possible in your manage > warnings. thanks
Message 3 of 8
in reply to: ennujozlagam
Thank you ! Sorry, but I do not know how to do this ''before opening the file tick audit and lastly clear as much possible in your manage > warnings''. Where AUDIT ? Please explain in steps how to clear warnings. Thanks !
Message 4 of 8
ennujozlagam
ennujozlagam
before opening your file tick audit
then clear or correct warning messages.
thanks
thanks
Message 5 of 8
I got to warnings window. But I don't know how to delete all those warning signs. Please explain how. Will deleting all warnings stop me from getting those error messages causing program to close ?
Also after every Revit closing like that it offers me to send report. Should I do that ?
Message 6 of 8
ennujozlagam
ennujozlagam
you can refer to these LINK and LINK and  LINK see if helps. thanks
Message 7 of 8
I got it ! I can not delete warnings I have to try to resolve them to keep it minimum. Thanks
Message 8 of 8
ennujozlagam
ennujozlagam
you can't delete them, everything. just resolve as much as possible. nice to hear that manage to solved your issues. thanks 😁😉😊
